Central Locking Not Working With Key Fob-SOLVED!!!
bestbass42
Post by bestbass42 »
Hello. Brought a 206cc today, 2003/03 reg. Tried to lock the doors tonight with the fob however the locks then pop up again & a bleep comes from the engine area (i presume its the alarm,havnt been under the bonnet yet as its too dark). I Can lock each door with the key. If i just lock the drivers door or the passenger door then open the other the alarm goes off so i know that works. Does anyone have any ideas? I Am not a mechanic so lots of info appreaciated!!!
Also roof isnt working either,it bleeps when roof locks are open & blind is across & i press switch. Blind in the boot seems a little loose compaired to other 206ccs ive brought.
Thanks in advance.
bestbass42
Re: Central Locking Not Working With Key Fob-SOLVED!!!
OK,thanks to DAVIEB on here PROBLEM SOLVED!!! The boot needed a good hard SLAM to shut,so thanks to Daviebs advice i adjusted the boot lock inside the boot-very easy just two star headed screws & the part moves up and down to adjust.So I did it and not only did it fix the popping up locks it also cured the roof which before didn't work!!! Jobs a good unn!!!
Thanks for feeding back the solution. May well help someone else in future.
