Any help welcomed :-)
Mister
Post by Mister »
We have just recently purchased a 206 cc, all is fine except for a slight issue with the roof. Basically the roof opens perfectly normal, however when closing we get beeping and no closing. We have to open and shut boot, then switch ignition, then push button and it all works perfectly again. Is only an issue with putting the roof back. I can only think that whilst driving something breaks contact whilst roof is in boot as we have to get out and open n shut boot and it works. Any ideas or remedies will be gratefully recieved.
Thank you for time
Re: Any help welcomed :-)
Hello & welcome (saves me answering your intro post)
Check the micro switch that tells the ecu the boot is closed ( switch "F" in this post )
Mister
Post by Mister »
Thank you for reply, I'll have a look when I get home from work and update if ok
