Hi all, I have an Allure with the JBL sound system installed and whereas most of the time at lower volumes, under 12, it sounds fine and really boomy due to the subs in the boot but go above 12 and certain frequencies make the rear panels and drivers door vibrate. Anyone know how to rectify this without replacing speakers? I would not mind upgrading the door and rear panel speakers in time but for the time being this is not an option. Is there a way of tightening the panels to stop the vibration? I find if I push my elbow on the drivers door it seems to calm down.
Cheers all
VIBRATION AT HIGH VOLUME
- Dav1ey
Ex owner of a 2005, 206cc Allure, Aegean Blue, 1.6 Auto with Cream leather ambience - *** SOLD *** and being loved in Essex
NEW Fiat 500 Lounge with Start Stop in Pasadoblé Red... Rampant Roller Skate
Norwich, UK
OUT, PROUD & PROBABLY BEING NAUGHTY!
Norwich, UK
shadow
Re: VIBRATION AT HIGH VOLUME
try adjusting the bass/treble/loudness via the HU
- Dav1ey
Loudness always on and will not switch off as I cannot stand it with it off, with bass reduced to -1 from +2 makes a slight difference but then sounds tinny, when I get it to how I like it and crank it up that is when it starts to vibrate hence wondering if trim can be adjusted etc.
Norwich, UK
Norwich, UK
You can buy self adhesive sound deadening which you can put on the inside of the offending panels. Search ebay. There is loads on there.
- Dav1ey
Aha, excellent, will give it a try! Cheers
Norwich, UK
Norwich, UK
