Indicators not working after replacing battery
dekockn
Post by dekockn »
Hi all. I've searched through the forum but have not been able to find a solution to my problem, so I hope you will be kind enought to help me out.
About 2 months ago, the battery on my Peugeot 206 CC 2.0 SE 2001 model died after the cold spell and the car not having been used for some time. I had the battery boosted and after driving all went well for the last two months. My wife then complained that the radio didn't work, so I checked the fuses but somehow didn't put the fuses back in their original positions. I decided to take the car to my local service station, but then the car wouldn't start once I got there. They advised me that they needed to replace the battery, which I had them do. I told them to check the fuses which they did. They then told me that all worked well, but now the indicators don't work - the "clicking" is very fast on both left and right turn indication, but the lights don't indicate. I have replaced the fuses in accordance with a diagram I found online (see attached)
Could this be due to the scorrect equence not being followed to replace the battery or maybe I got the fuses wrong? I read a recent post about resetting the BSI, could this help?
Any advice would be very much appreciated
