The car is an 05 206 1.6L hatch, manual, and I am in Australia. The car is second hand which I bought just over 3yrs ago, and so is out of dealer warranty. The clock has 110,000kms on it and is due for its major service.
I replaced the battery 6mths ago.
I have recently been getting 'spurious' warning messages like 'airbag fault', 'air pollution fault', but the airbag message stopped after awhile, and I assumed it was just the car going through a series of faults as the major service is due.
The vehicle has also been stalling sometimes when in motion and the clutch has been depressed. This is intermittent and in searching it looks like this is a common problem with no fix. The car also would not start for several turns of the key and then on the 8th turn the engine would start. This leads me to think that maybe that the fault may lie with the ignition cable?
I don't mind trying to fix things myself as it is a way I learn bits and pieces. I will have a look for one of those manuals you suggested. I downloaded a haynes manual for another (older) model but the images were sorely lacking. It is just such a pain that I cannot get a good look at the starter.
Do you know where the ignition might connect to the starter on this model of vehicle? All i can see (feel) is a large bolt (which is the main to the battery) and a small spade looking wire (which I assume is the earth). Touching the large bolt with a probe shows it has power getting to it when battery is hooked up
Cheers
