Driver side electric window issue =(
mrnick1986
Post by mrnick1986 »
Hi everyone,
I'm new round here so please bear with me. I did try finding the issue elsewhere but I couldn't really find my specific issue.
Basically when my windows go down, either by me pressing the button or putting the roof down, getting them back up again is a real problem. Sometimes pulling on the switch to get the windows to go up, will actually make them go down instead of up =(
Whether the roofs up or down the when you pull on the window switch the windows just wont come up, without some mega jiggling, and sometimes that don't work, you have to sit there for aaaaaages holding the switch up, then eventually, they'll come up if they feel like it.
Personally i think it's a problem with the switch or maybe the connectors to the switch, but thought i would give you guys a shout first =D
Any help would be greatly appreciated.
Re: Driver side electric window issue =(
Sounds like the switch. Using a multimeter I'd check the power supply to the switch first, then if that's ok, check the switch for continuity itself in all 3 positions. If a fault is apparent there then I should think a new switch should cure it.
Welcome to the forum. Let us know how you get on.
