Hello and Help
- highlander
Hello and Help
Just joined the anks of 206cc owners - an 04 plate quicksilver - and need advice on how to fit the wind deflector. Bad feeling I might have bought the wrong size for this model. Any tips?
04 Plate 1.6 quiksilver
Scottish Highlands
Scottish Highlands
- Thar
Re: Hello and Help
The wind deflector for the 206cc is a standard size for the car. Was it advertised as for the 206cc?
I've sent you a PM.
I've sent you a PM.
- highlander
Re: Hello and Help
Thanks Thar and also for the info in your message. I will have another go today. Yes it was advertised for the 206 but not sure if it came with all the right fixings.
Scottish Highlands
Scottish Highlands
Re: Hello and Help
It is pretty simple to fit. Two lugs to the back, then one rod to pull out each side. They fit into recesses. The deflector then folds up and down. It is difficult to go wrong.
Good luck.
Good luck.
