engine management light
TRIGGER
Hi I have a 2002 1.4 hdi, the engine management light has now been on for a few months.I took it to my local garage and had a fault detection test done and it came up with the following fault codes-0231 diesel high pressure regulating below preference and the other one was0704 clutch switch intermitent or no signal. any help or advice on how to rectify would be much appreciated. The fuel fillter was replaced a couple of months ago.
reap
Re: engine management light
heya. high presuure faults is normaly caused by a faulty injector. is it hard to start to?
TRIGGER
Hi no, it starts and runs as normal .looked on another forum and someone on there had 2 of the same codes as i have ,said it might be an earh fault or fuel pump relay. any ideas on how to rectify this problem would be much appreicated. thanks for your quick reply.
