Antipollution and Cat converter faults
Chef_dave_telford
Post by Chef_dave_telford »
bth come up at once driving home from work the other night car was fine all of a sudden pulled away from some lights and was very juddery and none responsive
any clues what to check first ?
Welcome to the forum. What car do you have?
Ollie
Post by Ollie »
:rotfl: :rotfl: :rotfl:
stacey206cc
Post by stacey206cc »
Mine Has the Engine management light on constantly - Antipollution fault text displayed - rattly sound from cat. (Sounds similar to heat shield rattle)
New cat £134 + vat from Leamoco.co.uk.
Should register the correct O2 levels and rectify the fault.
Bish Bash Bosh.
206cc 2.0i SE - Blue
gav23welsh
Re: Antipollution and Cat converter faults
Post by gav23welsh »
I've had this problem, and spent months trying to fit it...including buying a new cat.....my mate is a Peugeot specialist and the problem was the Lamber sensors....basically we removed them out of the exhaust system, simply cleaned them with carb cleaner and never had a problem since.
If your a bit of a DIY mecanic you could have a good yourself, i did mine :)
