Passenger wing mirror unit for 2003 206 cc
Wanted items, again only LEGAL stuff......
nicholaw
Post by nicholaw »
Hello - looking for a passenger side wing mirror unit for a 2003 206 cc as mine is currently held on with duct tape!
Colour not important as I have the cap off the current one.
I believe the connector for the wiring loom is black.
The mirror is heated and electronically adjusted but with manual fold-in.
Many thanks, :)
Nichola
Thar
Post by Thar »
You seen this viewtopic.php?id=11771? :)
Image...............
nicholaw
Post by nicholaw »
Thanks Thar, I've now contacted them
sunnydelight32
Re: Passenger wing mirror unit for 2003 206 cc
Post by sunnydelight32 »
Hiya, was just having a look through some posts and found yours. Did you say your wing mirrors fold right in manually? Wasnt sure if it was possible to have that!
It would be ideal as the little darlings round my area like kicking them off if there not folded in! :)
Thar
Post by Thar »
sunnydelight32 wrote:Hiya, was just having a look through some posts and found yours. Did you say your wing mirrors fold right in manually? Wasnt sure if it was possible to have that!
Yes they should. They can be a bit stiff though if they haven't been moved for some time. I would use some WD40 and try to fold them in carefully.
sunnydelight32
I will give it a try again, i had a little push but didnt want to break it! My other has been siliconed on so need to have it replaced!
Any ideas on best places to get a new drivers side wing mirror?
Thanks! Im loving this forum!! :)
Thar
Post by Thar »
Check out this post, could repairing yours be an option? viewtopic.php?p=106930#p106930 also this site but a little more expensive http://www.wingmirrorman.co.uk/peugeot% ... irror.html
sunnydelight32
Ive managed to fold in the one wing mirror that wasnt damaged :)
The garage that i got my car is going to have a look at the other one for me, not sure if he will replace it though but worth asking. Hes going to fix my drivers side door too, when i close it, it doesnt line up right and theres a gap at the window. Plus on my passenger side when i put the roof back up the small back window is sticking.
Thar
Post by Thar »
sunnydelight32 wrote:Ive managed to fold in the one wing mirror that wasnt damaged :)
Good, best to get everything sorted out by the garage as you've not had the car for long. Keep us posted.
