2003 206 maxi fuses.
pj180e
Post by pj180e »
I was wondering if anyone can help me. My cold/hot air fan has stopped working and I have checked all the fuses which seem ok. However, the handbook refers to a maxi fuse (20 amp) that operates the fan but I can't find the maxi fuse whereabouts?
Do you mean the fuse for the cooling fan located in front of the radiator? If so it is in the fuse box on the inner wing under the bonnet. Trace the fan wiring back to the fuse/relay box and you should find the large cooling fan fuse.
