Hi can anyone tell me where the ESP/ASR ecu is located. Not covered in the Haynes manual.
I want to check the connection as my warning light has come on or could it be a wheel sensor (ABS),
thanks
Where is the ESP ECU ?
reap
CherylJ
found another pug garage & this time the ECU reader worked
Came back saying brake pressure sensor fault.
The guy showed me where it is, bottom of brake master cylinder, & suggested its not to hard to change.
Had a look in the Haynes book but its not covered,
I can't see how its fitted, Screwed, push, or is it a part of the master cylinder, even my EPC is no help, must only cover the early models.
Have you changed one,
Again thanks for any info
