hi im not sure if i have put this question in the right place ?
Today i bought my 206cc everything seems fine with the car apart from one little thing there is a noise, sounds like its coming from the passenger side front foot well its like a hissing noise or air leaking it only happens when the car is turned on but when the break peddle is pressed it stops making the nosie any1 had this problem before ?
thanks sarah
(I have transferred this to the Problems section for you Sarah - GrandadMonkey)
The brake servo is on that side of the car, just in front of the passenger but under the bonnet of course. If that was leaking it could make a hissing noise. There will be a vacuum connection hose between the servo and the inlet manifold and that could leak too. I would get it checked out now while it is under warranty (presumably). Could be something as simple as tightening a connection, replacing the hose, or it could need a new servo at worst.
Get someone who knows cars to listen to it.
