Just fitting some Morette quads on the CC. Easy enough apart from.........
One wire.
On the passnger side headlight (only) there is a single wire with a 15Amp fuse that runs into a green relay box, this in turn runs to the main beam.
I've been advised that this must be wired up to the possitive conncetion on the battery.
However, another chap said it would work fine without this wire? Something to do with later models?
Any advice before I blow the car up would be welcomed.
Cheers
