Why would you do that?rblabs wrote:For the benefit of anyone still on boot unlocking issues, I do recommend or suggest you reverse the actuator's connecting wires. If you do this, your boot will unlock each time you press unlock on the FOB or any time the central lock is in open position. However you can then lock the boot with your key by turning clockwise! This is a better solution and someone out there can benefit asap. Let me know if this helps solving the problem.
Cheers.
It means every time you leave the car, you have to remember to lock your boot.
As it is, you only need to unlock it when you need to access anything in it.
I believe the reason it was done this way is so someone couldn't access your boot (when car is left with the roof down) by pulling up on the inside door knobs (earlier models)
