CC Survey - Please Complete.
206 cc problem questionnaire:
Your 206cc Forum User Name: Phly
(this is only used to monitor the fact that you are a
registered user of the forums and to ensure that each
person only submits one questionnaire - this obviously
helps us to make sure we capture good quality data).
What type of cc do you own:
2.0 (SE)
What Coutry do you live in:
South Africa
Date you collected your cc (just Month/Year is fine):
JAN 2003
Number of visits to dealer for corrective work so far:
2
Distance travelled so far (approx) Kilometres:
9500km
please answer yes or no to the following:
----------------------Suffered--Taken to--Fixed
----------------------from?-----Dealer?---
Roof Leaks?----------No-------No-------No
Problems Opening/Closing roof?
No, not really
Failing to start?-------No-------No--------No
Engine cutting out?---No
Windows rattling?-----No-------No--------No
Window seals
"squeaking"?----------No-------No--------No
Brakes "squeaking"?-No-------No--------No
Clutch pedal
"squeaking"?----------No-------No-------No
Any other problems - Please detail any other problems you may have encountered including those that were fixed by returning the cc to the dealer:
Pull-down/push up Roof locks squeek no and again - not fixed
Roof failed to open on one occasion - a minute later it was ok...and still is
Suspension was slightly out - car leaned over to the right - fixed
cord and toggle popped out - easily fixed
Clocks, meters and display lights went out twice with warning lights came on at same time - lasted for a few seconds - nearly caused heart-attack
2.0 (SE)
South Africa
JAN 2003
2
9500km
No, not really
Window seals
Clutch pedal
I've been to the year 3000. Not much has changed and we all drive Pugs
Your 206cc Forum User Name: gaia
What type of cc do you own: 1.6 auto
1.6 (S) Manual - Yes
1.6 (S) Automatic
2.0 (SE)
What Coutry do you live in: OZ
(just Month/Year is fine): April 2003
for corrective work so far: 1
Miles:
Kilometres: 2000
Roof Leaks?---------No-------No-------No
Problems Opening/
Closing roof?-------Yes---------------------
Failing to start?---No-------No--------No
Engine cutting out?-No
Windows rattling?---No-------No--------No
Window seals
"squeaking"?--------No-------No--------No
Clutch pedal
"squeaking"?--------No-------No-------No
1.6 (S) Automatic
2.0 (SE)
Miles:
Kilometres: 2000
Problems Opening/
Window seals
Clutch pedal
Your 206cc Forum User Name: pug77
1.6 (S) Manual
1.6 (S) Automatic
2.0 (SE) Yes
What Coutry do you live in: England
(just Month/Year is fine): March2003
for corrective work so far: 0
Miles: 20000
Kilometres:
Problems Opening/
Closing roof?-------No---------------------
Failing to start?---No-------No--------Yes
Windows rattling?---Yes-------No--------No
Window seals
"squeaking"?--------No------No--------No
Brakes "squeaking"?-Yes-------No--------No
Clutch pedal
"squeaking"?--------No------No-------No
No major problems after 20,000 miles which looking on here is pretty good. Squeaky brakes? Yes Have been told by pug mechanic not to use pug pads and go for mintex which should apparently cure the prob.
Build quality could be better but who cares. almost worn out the front tyres after 20,000 is that good ? I think its quite good considering the power going through those front wheels.
1.6 (S) Manual
1.6 (S) Automatic
2.0 (SE) Yes
Miles: 20000
Kilometres:
Problems Opening/
Window seals
Clutch pedal
2.0 (SE)
What Coutry do you live in: Wales
(just Month/Year is fine): OCT 2001
for corrective work so far: 3
Miles: 22000
Kilometres:
Roof Leaks?---------Yes-------Yes-------Yes
Problems Opening/
Engine cutting out?-Yes
Window seals
"squeaking"?--------Yes-------No--------No
Clutch pedal
"squeaking"?--------Yes-------Yes-------Yes
No other problems
2.0 (SE)
Miles: 22000
Kilometres:
Problems Opening/
Window seals
Clutch pedal
No other problems
THANK GOD WE'RE NOT IN THE CONFERENCE!
Your 206cc Forum User Name: Sooz
2.0 (SE)
What Country do you live in: England
(just Month/Year is fine): Feb 03
Miles: 4,200
Roof Leaks?---------no
Problems Opening/
Failing to start?----No
Windows rattling?---Yes - told that's what happens on the CC
Window seals
"squeaking"?---No-
Brakes "squeaking"?-Yes - asked for them to be checked at 6mth service
Clutch pedal
"squeaking"?--------no
Carpet coming away at driver's side under door seal - dealer tried once to fix and it's on the list when it goes for it's first service
Rear driver's window doesn't always come right back up at the first attempt
Water drips onto seats when you open door after rain; also if you drop window down after rain - guess this is a design fault
2.0 (SE)
Miles: 4,200
Problems Opening/
Window seals
"squeaking"?---No-
Clutch pedal
Your 206cc Forum User Name: 206Girl
1.6 (S) Manual
1.6 (S) Automatic
2.0 (SE) Yes
(just Month/Year is fine): July 2003
for corrective work so far: will be 1 this week
Miles: 150
Kilometres:
Problems Opening/
Closing roof?-------No-------No-------No
Failing to start?-----No-------No-------No
Engine cutting out?-No-------No-------No
Windows rattling?---Yes-------No------hopefully this week
Window seals
Brakes "squeaking"?-No-------No-------No
Clutch pedal
[/b]
1.6 (S) Manual
1.6 (S) Automatic
2.0 (SE) Yes
Miles: 150
Kilometres:
Problems Opening/
Window seals
Clutch pedal
[/b]
Your 206cc Forum User Name: timbo
1.6 (S) Manual
1.6 (S) Automatic
2.0 (SE) - YES
What Coutry do you live in: Australia
(just Month/Year is fine): FEB 2003
Miles:
Kilometres: 11000
Problems Opening/
Window seals
Clutch pedal
Nil
1.6 (S) Manual
1.6 (S) Automatic
2.0 (SE) - YES
Miles:
Kilometres: 11000
Problems Opening/
Window seals
Clutch pedal
Nil
new on the block
Your 206cc Forum User Name: SL22UK
1.6 (S) Manual
1.6 (S) Automatic
2.0 (SE) - YES
(just Month/Year is fine): Dec 2001
for corrective work so far: 9
Miles: 5500
Problems Opening/
Window seals
Brakes "squeaking"?-Yes-------Yes------Yes
Clutch pedal
"squeaking"?--------Yes-------Yes--------Yes
Radio loses its memory
1.6 (S) Manual
1.6 (S) Automatic
2.0 (SE) - YES
Miles: 5500
Problems Opening/
Window seals
Clutch pedal
Having had 2 206cc's and covered 75,000 miles plus I think I can safely say I have a view.
These cars have been
A) The most comfortable
B) The most fun
C) The best cars I have owned (and probably driven) since I passed my test in 1967.
NO LEAKS
Excellent service
And lots of interested glances.
I have two friends with the Mercedes "folding roof" cars and both have had more problems than any Pug driver I've heard of.
Let's celebrate the fact that we have the BEST budget convertable available, compare it with the Golf, MG and Megane - no competition
B) The most fun
NO LEAKS
Excellent service
Owner 100
Now Owner of RA53EHX -307cc from October 2003 Now on 12,800 miles. One or two very minor niggles, Overall a very good motor.
First 206cc - Y689PMO - May 2001 to March 2002 - 28,800 miles
Second 206cc - RX02CCO - March 2002 to October 2003 - 46,900 miles
Total mileage to October 2003 - 75,700 miles
No leaks or problems!!
http://www.ewingtoncooper.co.uk
1.6 (S) Automatic
2.0 (SE)
What Coutry do you live in: Greece
(just Month/Year is fine): May 2002
for corrective work so far: 7
Miles:
Kilometres: 14000
Problems Opening/
Window seals
Clutch pedal
Problems when engaging reverse gear. (Squeaking). Replaced the clutch system.
Water leak in the engine comparment.(Fixed)
1.6 (S) Automatic
2.0 (SE)
Miles:
Kilometres: 14000
Problems Opening/
Window seals
Clutch pedal
Your 206cc Forum User Name: Nobby
1.6 (S) Manual -
1.6 (S) Automatic
2.0 (SE) Yes
(just Month/Year is fine): July 03
Miles: 1600
Kilometres:
Roof Leaks?-------No--------No-------No
Problems Opening/
Window seals
Clutch pedal
The passenger door had to be slammed to shut it,and Boot was out of allignment, both problems sorted at dealers
[ This Message was edited by: Justin on 2002-03-18 14:27 ]
[ This Message was edited by: Justin on 2002-03-19 12:00 ]
1.6 (S) Manual -
1.6 (S) Automatic
2.0 (SE) Yes
Miles: 1600
Kilometres:
Problems Opening/
Window seals
Clutch pedal
Member No 775
Member No 775
Your 206cc Forum User Name: Boyracer
What type of CC do you own: 2.0 (SE)
Date you collected your CC: 01/04
Number of visits to dealer for corrective work so far: NIL
Distance travelled so far (approx) 4,600KM
Please answer yes or no to the following:
Roof Leaks?---------NO-------N/A-------N/A
Problems Opening/
Closing roof?--------NO-------N/A-------N/A
Failing to start?-----YES-------NO--------N/A (Only happened once. Sounded like an old bomb when it did, though.)
Engine cutting out?-NO-------N/A-------N/A
Windows rattling?---NO-------N/A-------N/A
Window seals
"squeaking"?--------NO-------N/A-------N/A
Brakes "squeaking"?YES-----NO-------N/A
Clutch pedal
Carpet comes away at sides under door seals. Not taken to dealer yet.
Problems Opening/
Window seals
Clutch pedal
Cheers,
Michael
:shock: [url=http://www.peugeot206cc.co.uk/newowners?id=575]Owner 575[/url]
Michael
Your 206cc Forum User Name: jem
1.6 (S) Manual
(just Month/Year is fine): NOVEMBER 2003
Number of miles travelled
so far (approx): 2000
Problems Opening/
Window seals
Clutch pedal
1.6 (S) Manual
Problems Opening/
Window seals
Clutch pedal
