CC Survey - Please Complete.
206 cc problem questionnaire:
Your 206cc Forum User Name: kaanabak
(this is only used to monitor the fact that you are a
registered user of the forums and to ensure that each
person only submits one questionnaire - this obviously
helps us to make sure we capture good quality data).
What type of cc do you own:
1.6 (S) Manual
1.6 (S) Automatic ----YES
2.0 (SE) - Automatic
What Country do you live in: Turkey
Date you collected your cc
(just Month/Year is fine): Bought September 08
Number of visits to dealer
for corrective work so far: 0
Distance traveled so far (approx)
Kilometers:66700-I made 3600 till Sep 08
please answer yes or no to the following:
--------------------Suffered--Taken to--Fixed
--------------------from?-----Dealer?---
Roof Leaks?---------Yes-------No-------No
Problems Opening/
Closing roof?-------No-------No-------No
Failing to start?----No--------No--------No
Engine cutting out?-No--------No--------No
Windows rattling?---Yes--------No--------No
Window seals
"squeaking"?--------Yes------ No--------No (only when wet)
Brakes "squeaking"?-No--------No--------No
Clutch pedal
"squeaking"?--------No--------No--------No
Any other problems - Please detail any other problems you may have encountered including those that were fixed by returning the cc to the dealer:
No Problem except suspensions are too hard,causes car shake hardly even smooth roods. dont know its broken or have a sport setting..Gonna chenk next month..
1.6 (S) Manual
Problems Opening/
Window seals
Clutch pedal
Suzzie1976
1.6 (S) Manual - Yes
What Coutry do you live in: England
(just Month/Year is fine): March 2007
for corrective work so far: 1
Distance travelled so far (approx)
Miles: 14000
Roof Leaks?---------No------ No------ No
Problems Opening/
Closing roof?-------No---------No-------No-
Failing to start?--- No-------No--------No
Windows rattling?---Yes-------No--------No
Window seals
"squeaking"?--------Yes-------No--------No
Brakes "squeaking"?-Yes-------No--------Yes
Clutch pedal
"squeaking"?-------No-------No-------No
The drivers side window randomly came down without me touching anything and got stuck down. The RAC man couldn't fix it. I took it to the dealer who fixed it under warrenty - The window switch had broken.
Suzzie1976
Miles: 14000
Problems Opening/
Window seals
Clutch pedal
Fleabum
2.0 (SE) - Manual (03 plate)
England
OCT 2008
1
Miles: 6500
-------------------------Suffered--Taken to--Fixed
-------------------------from?-----Dealer?---
Roof Leaks?-----------Yes--------no--------no
Problems Opening/
Closing roof?----------No
Failing to start?--------Yes-------no--------no
Engine cutting out?---No
Windows rattling?-----No
Window seals
"squeaking"?----------Yes--------no--------no
Brakes "squeaking"?-Yes--------no--------no
Clutch pedal
"squeaking"?----------No
Lumpy engine start when cold.
Cat fault after washing car.
Anti-pollution fault after washing car.
Driver door window leaks when washing car.
Passenger door window does not close into the door seals when shut, it has to be pressed to click it into the door seal (does not happen if the window is slightly down.
Slight squeaking brakes on presure.
Fleabum
England
OCT 2008
1
Miles: 6500
Problems Opening/
Window seals
Clutch pedal
Your 206cc Forum User Name: Grossy144
1.6 (S) Automatic
2.0 (SE)
(just Month/Year is fine): July 08
for corrective work so far: 2
Miles: 6500
Kilometres:
Roof Leaks?---------Yes-------Yes-------Yes
Problems Opening/
Closing roof?-------yes--------------------
Failing to start?-- -----No--------
Window seals
Brakes "squeaking"?- --No
Clutch pedal
"squeaking"?----- NO
Backlight behind front display not working
1.6 (S) Automatic
2.0 (SE)
Miles: 6500
Kilometres:
Problems Opening/
Window seals
Clutch pedal
1.6 (S) Automatic
2.0 (SE)
What Coutry do you live in: Bosnia and Herzegowina
(just Month/Year is fine): OCT 2002
Miles: 6500
Kilometres:
Roof Leaks?---------no-------no-------no
Problems Opening/
Closing roof?-------No---------------------
Failing to start?---no-------No--------Yes
Window seals
Brakes "squeaking"?-no-------No--------No
Clutch pedal
"squeaking"?--------no-------no-------no
passengers seat was stuck was fixed but now its fallin when u lean stronger
1.6 (S) Automatic
2.0 (SE)
Miles: 6500
Kilometres:
Problems Opening/
Window seals
Clutch pedal
Your 206cc Forum User Name: Rabuto
What Coutry do you live in: Kent, England
(just Month/Year is fine): 5th May 09
Number of miles travelled
so far (approx): Approx 1000
Roof Leaks?---------No-------No-------No
Problems Opening/
Closing roof?-------No--------No-------No------
Failing to start?---No-------No--------No - But starter motor sticks sometimes
Windows rattling?--Yes-------No--------No
Window seals
"squeaking"?--------Yes-------No--------No - Have tried a grease which same as what Pug sell but cheaper and also also dry silicon spray, which work really well. Will post info on these products.
Brakes "squeaking"?-Yes-------No--------No - Not always though
Clutch pedal
"squeaking"?--------No-------No-------No
Any other problems - Please detail any other problems you may have encountered including those that were fixed by returning the cc to the dealer: None
Carpet comes away at sides under driver side door seals.
Problems Opening/
Window seals
Clutch pedal
Fear is just a feeling, fear cannot kill you!
1.6 (S) Automatic
2.0 (SE)
(just Month/Year is fine): June 2009
Miles: 85000
Kilometres:
Roof Leaks?---------No-------no-------no
Problems Opening/
Closing roof?-------Yes-----No--------Yes--------
Windows rattling?---No
Window seals
Clutch pedal
Carpet comes away at sides under door seal of Drivers side,
Gear stick has slack either side and can move when in gear
Bonnet rattles - cant seem to adjust ourselves
Boot rattles when roof in the boot occasionally
Saved Radio channel CH1 FM1 changes from local Heart FM to BBC radio 2 on occasions.
1.6 (S) Automatic
2.0 (SE)
Miles: 85000
Kilometres:
Problems Opening/
Window seals
Clutch pedal
1.6 (S) Automatic
2.0 (SE)
(just Month/Year is fine): oct 2006
Miles: 30000 ish
Kilometres:
Roof Leaks?---------Yes-------no-------no
Problems Opening/
Failing to start?---no-------No--------no
Window seals
"squeaking"?--------no-------No--------No
Brakes "squeaking"?-Yes-------No--------yes
Clutch pedal
"squeaking"?--------Yes-------no-------no
Loosing power exiting junctions in 1st gear, took it to peugoet garage, they found nothing wrong but it still does it occasionally???
If this is collecting complaints about peugoet garages the dealer i used damaged all 4 locking wheel nuts to the point they had to be drilled off. the garage that changed the tyres before that were good enough to change them for a lot less than dealer.
won't go to dealer again!
1.6 (S) Automatic
2.0 (SE)
Miles: 30000 ish
Kilometres:
Problems Opening/
Window seals
Clutch pedal
Your 206cc Forum User Name: burger
What type of cc do you own: 1.6 (S) Manual
Date you collected your cc: MARCH 2007
Number of visits to dealer for corrective work so far: NONE
Distance travelled so far (approx) Miles: 33000
Suffered Taken to Fixed
from? Dealer?
Roof Leaks? NO N/A N/A
Problems Opening/Closing roof? NO
Failing to start? NO
Engine cutting out? NO
Windows rattling? NO
Window seals "squeaking"? NO
Brakes "squeaking"? YES
Clutch pedal "squeaking"? NO
Carpet comes away from the drivers door seal and is now very loose (very annoying).
Actuator failed on drivers door.
Paint defect on drivers side wing mirror (cracking).
faint creaking from chassis when driving on rough surfaces (but I suppose this is quite normal from any convertible ).
I hope this helps!
from? Dealer?
I hope this helps!
Your 206cc Forum User Name: 52nd of February
What type of cc do you own: 1.6 (S) Tiptronic
What country do you live in: Australia
Date you collected your cc: January 2009, new October 2004
Number of visits to dealer for corrective work so far: Once with previous owners, three times since I've owned it.
Kilometres: 57,000
from? Dealer?
Roof Leaks? Yes No
Problems Opening/
Closing roof? No
Failing to start? Yes No Yes
Engine cutting out? No
Windows rattling? Yes No No
Window seals
"squeaking"? Yes No No
Brakes "squeaking"? Yes No No
Any other problems - Please detail any other problems you may have encountered including those that were fixed by returning the cc to the dealer: Previous owners took the car back under warranty when the front windows failed - newer, stronger window motors were installed.
"AIRBAG FAULT" message recurred for a while - fixed with ECU settings reset and a new battery
Ignition turning on, but then everything tripping when started - turned out to be the positive battery terminal being shaken loose - just need to watch it
Irratic gearbox from idle into 1st after stopping - no movement when the accelerator is depressed, must be revved really high before a loud clunk and then car lurches forward - fixed with ECU settings reset and Premium Unleaded used from now on - problem completely gone
CD player stopped working, some components jammed and locked together - sent back to Clarion and fixed
Kilometres: 57,000
from? Dealer?
Roof Leaks? Yes No
Problems Opening/
Closing roof? No
Window seals
Last edited by 52nd of February on Sun Oct 18, 2009 12:18 pm, edited 1 time in total.
Your 206cc Forum User Name: ashbash
1.6 (S) Manual - yes
1.6 (S) Automatic
2.0 (SE)
What Coutry do you live in: Scotland
May 2009
so far (approx): 6000
Roof Leaks?---------Yes-------no------Yes
Problems Opening/
Window seals
Clutch pedal
Anti - Pollution Fault
1.6 (S) Automatic
2.0 (SE)
May 2009
Problems Opening/
Window seals
Clutch pedal
Your 206cc Forum User Name: CATE
1.6 (S) Automatic
2.0 (SE)
(just Month/Year is fine): OCT 2003
for corrective work so far: 4
Miles: 78000
Kilometres:
Problems Opening/
Closing roof?-------Yes--------Yes-------No (too expensive, wondering what to do)
Failing to start?---Yes-------No--------Yes
Window seals
Clutch pedal
"squeaking"?--------Yes-------no---------No
Passenger seat seems to have a life of its own sometimes. Not always easy to secure/move. Not referred to dealer.
Electrical meltdown in year 5. Never did find out what caused it. Everything just "stopped". Dealer mystified. Took it back several times. In the end, the dried out the engine. No recurrence.
Indicators, headlights and fog lamps randomly switched on and off (mostly off). started with faulty LH indicator. Replaced switch at dealer.
Always replacing bulbs - especially the one over the rear number plate
electric oil indicator has NEVER worked. Purchased from new. Prefer the dipstick anyway, so never bothered.
Was told leaky roof seals because I had roof down so much, even in frosty weather. Repaired under warranty.
Tyres/tracking. Maybe its because I live in a rural area - but I get through tyres like you wouldn't believe. And my tracking never stays in place for more than 3 months.
Someone tell me why I love this car again??
1.6 (S) Automatic
2.0 (SE)
Miles: 78000
Kilometres:
Problems Opening/
Window seals
Clutch pedal
