Hi All,
My "new" 206cc has developed a small leak on the driver side (that would be the left side in my case) it is not a big leak, about 1 espresso cup during an overnight rain.
I wanted to try the silicone grease fix recommended in other posts but I ca not find a local product and the named products like "Servisol" are not sold here in Macedonia. I purchased a can of Silicone lubricant (MOTIP Silicone Spray) recommended for rubber parts but in the contents it is listed that it contains petroleum. There was a note in some of the posts that unless it is silicone it might burn the rubber.
So the question, can I use this spray, or should I search for a different solution?
Can someone name several products corresponding to 'silicone grease' so I ca find one that is sold locally?
BTW, I found out that a plastic cup held by a suction phone holder works wonders for catching water drips, although looks funny from the outside (image).
Driver side leak from roof joint
2001 206cc 2.0 S16
2001 206cc 2.0 S16
Re: Driver side leak from roof joint
Vaseline will stop the leak and not harm the rubber.
Update: I found locally Carlube Silicone grease (link below) and filled every crevice with it. Hopefully it will be OK. Weather forecasts rain on Monday, so well see...
This is the grease: (- instead of dot)
www-carlube-co-uk/greases/carlube-silicone-multi-purpose-grease
2001 206cc 2.0 S16
2001 206cc 2.0 S16
We had heavy rain and 40cm of snow and than some light but long lasting rain.
NO DRIPS inside! My CC is a happy CC
2001 206cc 2.0 S16
2001 206cc 2.0 S16
Well done. Result!
