Portal » Forum   FAQ   Search
Register  Login
Portal » Forum 206CC Forums 206CC General
Roof motor keep working and dont complete cycle
Postby Issac55555 » Wed Sep 20, 2017 6:26 pm
Hello frainds ... i have a problome..
My roof workes fine , but when the boot close and the latches cathe work .. the motor keep working and there is no beep soud that tall that the computer finish the operetion..
So i got the issue that the car beeping while drive ang when i open the roof, the windoes dont go dwon with the roof ...
Sombady know how to solved this???
Issac55555
Re: Roof motor keep working and dont complete cycle
Postby Spitfire6 » Sat Sep 23, 2017 1:27 am
Hi & Greetings.
Go to the rear of the car and push down on the boot lid close to the front of the car on the port and starboard side until it clicks. Fix the bleeping?
Cheers,
Iain.
206 CC 2L owner. 2002
Triumph GT6 Soft-Top 6Cyl 2.5EFI . 1972
G6SBH.
Spitfire6
Postby gazza82 » Sat Sep 23, 2017 2:20 pm
He's also asked in Roof section ...
Family Fleet: ex-Cayman Green 206 CC 2.0 LE, Indigo Blue 206 1.4 HDi Hatchback, Alfa Romeo MiTo, Renault Clio II 1.5dCi
Postby Issac55555 » Sat Sep 23, 2017 3:43 pm
Thanks friends, leaning on the trunk does not help at all, the lock is done before using the main electric button, I do not know why the computer does not get a command that the roof has finished ... Are there any ideas ???
Issac55555
Postby gazza82 » Sun Sep 24, 2017 9:09 pm
Isaac ... stick to you post under Roof or you'll end up with split answers.
viewtopic.php?f=5&t=17419
Mods: lock this one.
Postby Issac55555 » Mon Sep 25, 2017 2:26 am
Ok , im soory ... tnx
Issac55555
Return to 206CC General
Who is online
Users browsing this forum: No registered users and 1 guest
cron
