Portal » Forum   FAQ   Search
Register  Login
Portal » Forum 206CC Forums 206CC General
206cc speedo not working ???????
Postby sharronanne » Sun Jul 23, 2017 5:21 pm
hi all
I have a 206cc 1.6 2003 and the speedo has not worked since we brought it a month ago
we have tried.....
speedo change / speedo sensor in gearbox / checked fuses / cleaned earth leads / checked for broken wires ..
everything else works just the speedo doesn't ..
help !!!!!!!!!!
sharronanne
Re: 206cc speedo not working ???????
Postby IanL » Sun Jul 23, 2017 7:08 pm
Have you tried a BSI Reboot?
Postby sharronanne » Sun Jul 23, 2017 7:41 pm
hi
just done a bsi reboot 4 times and still its the same ??????
sharronanne
Postby Slo » Sun Jul 23, 2017 9:36 pm
It will be the speedo drive cog that makes the spindle spin, has it had a recent clutch change? The usual cause is when inserting the long drive shaft into the box, it breaks the plastic lugs off the drive cog or dislodges it then when the diff turns the cog gets chewed up.
Having said that though, this problem usually throws up abs fault, airbag fault and disabling of the roof for safety as the car knows when its moving but cant actually detect it.
This pair is from a 205, on the 206 they are both black, its the larger of the two that breaks easily.
2002 02'reg Peugeot 206cc 1997cc Manual
Slo
Postby IanL » Sun Jul 23, 2017 10:13 pm
According to the SEDRE, if the vehicle has ABS or ABS+ESP, there is no vehicle speed sensor, and the data seems to come from the ABS/ESP ECU.
Postby Slo » Sun Jul 23, 2017 10:16 pm
I dont know what models have that speedo working from the abs ecu but i was advised that too when mine wasnt working. Out of every single one of these cars I looked at in scrap yards all of them had a speedo sensor including mine which was the cause of mine not working too.
Slo
Postby sharronanne » Mon Jul 24, 2017 8:51 pm
yeah took speedo drive out and it looked fine . even spun it up with a drill and still the speedo doesn't work.
put new speedo sensor in the gearbox with the new drive that came with it..
my cars an automatic so not sure if that makes any difference ..
everything else works and the car drives perfectly ...
sharronanne
Postby IanL » Tue Jul 25, 2017 2:00 pm
I suggest you get Peugeot Planet 2000 onto it - it may point to some part of the electronics, perhaps in the ABS/ESP.
Return to 206CC General
Who is online
Users browsing this forum: No registered users and 3 guests
