rear lights
rear lights
I thought I would share , while I was repairing damage to rear panel I took both rear lights out so not to get paint on them had water in both ,found that the glue holding the lens on had given up allowing water ingress so cleaned up re glued back on then put clear builders silicon in the small gap ,cleaned off works a treat
Re: rear lights
This is a common fault with the water filling up the lens. I did not know it was where the glue had failed. Cost £17 for new bulb holder due to the corrosion.
206cc 1.6 2002 Silver.
L200 2.4 Forlife (wifes)
Re: rear lights
I had to replace one rear lens cost of £30 s/h included bulb holder these are all done now rear 1/4 panel sprayed this afternoon now onto replacing wing and small door repair ,that was all the damage ,then the biggy of getting roof to work ,but I bought it like this ,then the leather seats to re stain red and black ,,then off for mot no rush
