Roof ECU/Microswitches/Relays
Re: Roof ECU/Microswitches/Relays
Thank you for your help. It's all working as it should thanks to you.
Well done to you, and to Wee Smurf for helping you to do it economically. Good to see some sound advice.
Great stuff Dan, glad its fixed, now you can enjoy the Sun if it appears . If you need anything else just let me know, got piles of CC stuff and super cheap!.dbdbdb wrote:Thank you for your help. It's all working as it should thanks to you.
Hi folks, just a heads up for anyone looking for any CC parts, virtually anything you need for your CC i will probably have including panels /hydraulic rams/roof ecu/pump/cables/latches,etc etc etc, and everything will be tested fastidiously before sending!, (have 2 CC's on the road which will be used for testing any parts to verify good working order), and much cheaper than ebay prices too! .
Just wondering if you have any micro switches available ?
Thanks !
Thanks !
Hello Wee Smurf,WEE SMURF wrote:Dan, if you look at this link.....
http://www.peugeot206cc.co.uk/repair-20 ... ak018d.gif
Are the switches you need J and E?.
If you still need them give me a call around teatime and i will sort it out for you.
Are all microswitches "normally open" or "normally close" contacts?
206cc 1.6 16V Petrol
Al4 Transmission
Al4 Transmission
Still have all switches available folks, also roof pump, hydraulic rams etc etc. Piyas.. depending on which switch they can be either open or closed.
Can you advise why my microswitches for the rear shelf (C,I,D microswitches) are on a PCB unlike yours on my 2005 206cc 1.6 petrol? Does the reading needs to be totally zero when open? Since I measured 6k ohms, thus not totally open and should be replaced?
[URL=http://s1044.photobucket.com/user/ ... .jpg[/img][/url]
Al4 Transmission
Al4 Transmission
Closed it should be pretty much zero Ohms.
Try squirting electrical cleaner into it and operating it.
Mine failed so I bridged the wires so it thought the shelf was closed so I could put the roof down untill I replaced the switch
Hi. I need one fo those microswitch. Can you contact me? thanks
Does anyone have the micro switch?
