Breaking 05 plate blue 206 CC 1.6 Allure
Re: Breaking 05 plate blue 206 CC 1.6 Allure
You never know what you are getting 2nd hand.
Some folk have tried a repair.
http://philsworkbench.blogspot.co.uk/20 ... epair.html
page06
Post by page06 »
Great stuff I shall have to try a clean..thanks :)
Enright
Post by Enright »
Failing that there are loads on the Bay of e. Make sure you get one from a reputable trader though who states categorically that all functions work. Then you have comeback if they don't.
BCingU,
Neil. ;)
page06
Post by page06 »
thanks for the help all..
page06
Post by page06 »
Hi guys UPDATE I removed and cleaned the comm2000 wiped contacts ect very greasy and lots of dirt!! SEEMS TO HAVE WORKED!!! thanks Grandadmonkey for info!!!! fingers crossed it stays good :thumbs: thanks again all :)
Well done page06. Pleased to be of help. It is always worth having a go at cleaning up your own COM2000 before going to the expense of buying a new one.
JMT_1989
Post by JMT_1989 »
do you have the passanger wing for sale ?
Thanks.
Enright
Post by Enright »
The front end panels all went very quickly I'm afraid. The only outer panel I have left is the passenger door, sorry. You'll have to either try eBay, or I recommend pug206ccspares in Cheshire (pug206ccspares@hotmail.com).
BCingU,
Neil. ;)
Ricky5555555
Post by Ricky5555555 »
Hi there, do you have a N/S/R brake disc dust cover
Enright
Post by Enright »
Sorry, no. The back axle went complete with everything except for the wheels.
BCingU,
Neil. ;)
Enright
Post by Enright »
With the usual glut of "first time use this year prompting discovery of roof problems", it's worth mentioning this here before I (and others) potentially waste time and money on eBay:
I still have a nearly complete roof assembly available in KMF blue. It has all of the microswitches, wiring, hydraulic rams, pipework, headlining, decent seals and an intact rear window. In fact the only thing that's missing is the pump because that was sold separately.
I'm looking for £50 for it, but it would need to be collected.
I also have a roof ECU which came off the same car, and worked fine before it was removed. That's £25 which includes P&P.
Send me a PM if interested (or post below and I'll hopefully pick up on it next time I log in).
BCingU,
Neil. ;)
a1i.cu
Post by a1i.cu »
I've just found this site as I am now the owner of my mum's 206CC now that she's passed away. It's a 2002 model with less than 20,000 on the clock!! :yikes:
Anyway, I was wondering if you have the passenger side plastic bit that attaches to the front of the rear window - as the passenger window/door doesn't close properly, the plastic is now ripped.
I'm also after the metal work that surrounds the automatic gear lever.
Do you think, in your experience, that I'll also need something to fix the issue that my passenger door doesn't unlock when using the key fob nor sometimes pulling the lock knob up...
Thanks :big-grin:
Silver Peugeot 206 CC 2002.
got July 2014, 19,500 miles on the clock - and the roof works too :)
Sorry about your Mum, but congratulations on your inheritance. Sounds mint! Did she ever have the timing belt renewed?
Sounds as if you need a new actuator for the passenger door lock, the solenoid has probably failed. I'd check the wiring terminals first though in case something has come adrift there.
Welcome to the forum.
a1i.cu
Post by a1i.cu »
Not sure about the timing belt - it goes ok until 15 miles then the engine doesn't engage when stopped so jolts when it does - but my way round it is to put it into Snow, then it stays ready to go. So it's not mint (if you see me post in the newbie section, you'll read I've done some damage to it while she still owned it opps!
I'll check the wiring looms at some point. Thanks grandadmonkey :)
fbs1000
Post by fbs1000 »
Hi mate,
Do you have the engine / bonnett sound/heat proofing please?
Cheers, Richard
PM me please - cheers
