hi all i have a 206 sw verve.when i start the car it starts with no problems,but now and again the throttle does not work when pressed,if you turn off the car a couple of times it will start and throttle will work.this problem has got worse over recent months.my local garage has done a diognostic check that returned nothing.we replaced the electronic throttle unit with no look.can anyone help
darron
(56 plate)
206 hdi throttle problem
Re: 206 hdi throttle problem
Sounds like APP going faulty (Throttle pedal sensor) You could try recalibrating it.
To reset pedal
Pedal position sensor programming procedure
• accelerator pedal at rest,
• switch on the ignition,
• press the accelerator pedal down fully,
• release the accelerator pedal,
• start the engine without accelerating.
Good luck
To reset pedal
Good luck
hello. this is a well known fault. it is corrupt engine ecu software.you need to get booked in to have a software update
