Hi gurney255 and welcome to the forum.
Thanks for taking the time & trouble to upload photos and hints. I'm sure many on here will find them useful
MY ROOF ONLY OPENS HALFWAY HELP PLEASE!!!!!!!!!!!
Re: MY ROOF ONLY OPENS HALFWAY HELP PLEASE!!!!!!!!!!!
bah the roof is stuck again but in its final position, its down but the boot lid wont lock in and the roof wont move at all now and its due to rain here very soon
any ideas please speedy if possible lol
Have you checked the boot closed microswitch & cable adjustment for the boot locks? Sounds like cables may need tightening slightly.
If you can't sort it- better put it up manually
Gurney255, you are a lifesaver! Finally found this post, same symptoms as i have been having.
Been scratching my head for weeks on this one, changing lots of parts etc.
Microswitches had all tested fine, however i just took this one off and it wasn't moving freely. Free'd it up, and roof works properly!
Tks
Matt
Tks
Matt
Glad you got the roof sorted!
Ex 206 CC'er.
Tks yl! Massive relief after so long!
I sent you pm the other day, but not sure if it sent. Tks also for that info if the pm didn't get thru!
Matt
Matt
Gurney 255 you are a legend it fixed my roof many thanks
Having same issue on my cc!
Can get to the point the roof is in the boot but the boot lid will not close and parcel shelf won't eject!
Can hear the pump change pitch at this point then ten seconds later...the ECU safety turns the pump off.
Going to test my roof switch to see if it's faulty
gurney255 wrote: ↑Sun May 20, 2012 1:29 pm Finally found the solution
Since the comp measure the time it stops the opening while it didn't received the signal from switch that roof has been opening. The switch is located here:
You will need the torx 20 to remove it. Mine was not damaged, just it required few clicks to move again. Everything is fine now and I avoided to pay a lot of money for services, since they wanted to replace all actuators instead one f** micro switch.
Any questions, feel free to write.
Lifesaver post!! Thank you Gurney255 .....
