Hi all,
I have an issue with the driver side latch, everything else on the car is fine (checked via dealer software), I need to get to the roof latch on that side to check to see if there is just an issue with a bent microswitch arm.
How do I actually get to the latch? I can see a single torx bit holding part of the trim on at the latch, where are the other screws/fasteners? Does it just pull away?
Basically the driver side latch can be unlocked, however the car can't sense it has been unlocked, the passenger side is fine. This is the reason why when both latches are unlocked there aren't any beeps - as the car isn't aware that the driver side latch has been unlocked.
Thanks in advance!
