Wanted Fuse Board
Want something, have something someone else may want? check here...
justme1972
Wanted Fuse Board
Post by justme1972 »
Looking for the under bonnet fuse box part number 9646405280 DBM B3. Has anyone got one for sale please.
Re: Wanted Fuse Board
Ebay is probably your best chance. Did you get the codes read?
justme1972
hi capncol had the car fault code read and the only code was a speed sensor on the front,got hold of a second hand fuse board today and fitted it...car still wont start,what i did check was to see if iv got a spark witch it has and a good one at that. then the day light ran out lol....what im trying to find is what is the coulor of the power feed out the ecu for the fuel pump or the wire from the pump its self as iv tried to understand a wireing diagram over the weekend and still carnt sus it pmsl. sorry to be a pain keep asking but it can only be somethink stupid now surley
OK. Back to the beginning. How did you arrive at the power to fuel pump being an issue? How did you test?
