Wheel stud covers
Wheel stud covers
Hi all just just purchased four 16inch pug wheels for my 206cc. The car originally had 15 inch wheels. I have noticed that the wheel stud covers from my 15inch wheels dont seem to suit the 16 inch wheels. They protrude too much. It looks ugly and before I purchsse new stud covers does anyone know if the stud covers are unique to the wheel size. No one here can tell me and as I already have a set from the original wheels I don't want to buy anotger set if they are the same. This is all long winded but I have done my best to explain my quandry
Re: Wheel stud covers
Were your old wheels alloy with bolts with the built in flat washer?
There are two bolts sizes: 17mm and 19mm (the head size). For 16" rims I would use the 19mm bolts as they look a better fit in the wheel bolt holes. I bought a pack of chrome caps from fleabay for ours and most of the caps were loose. Didn't bother to fit them ...
You can get chromed bolts but I can't vouch for the quality .. and how quickly they rust!
If not you may need to change the bolts too as the taper seats are the wrong shape and will break through the new wheels.There are two bolts sizes: 17mm and 19mm (the head size). For 16" rims I would use the 19mm bolts as they look a better fit in the wheel bolt holes. I bought a pack of chrome caps from fleabay for ours and most of the caps were loose. Didn't bother to fit them ...
Thank you. The bolts look like your first pic but I am going to check now just to be sure.
Again thank you
Again thank you
I can safely report that the bolts are 57mm long with the head measuring 17mm they are identical to your second pic. So all good there.
