206cc gearbox replacement
Hi I would like to buy a 2006 206 cc 1.6 patrol but it has a bad gearbox how much a good used or new one cost, and dose a 206 gear box fit in the 206 cc ?
Re: 206cc gearbox replacement
This is typical. Don't forget the cost of labour, unles you intend to DIY.
If you have the gearbox out, it is sensible to change the clutch at the same time, so factor that in as well.
I believe there are two types of manual gearbox in the hatchback and cabriolet. If you quote the last eight digits of the VIN, I can tell you which you need.
if i give last 8 digits of my car could you tell which gearbox i need thanks
Or you can read the 6 digit code from the bottom of the gearbox
Yes.cossiejay wrote:if i give last 8 digits of my car could you tell which gearbox i need thanks
